Jinshu_134425
May 31, 2016Nimbostratus
Solved
Strange Problem- F5 APM
Hi Folks,
We are facing strange behavior on F5 APM which sends RST packets while login to the portal. We have tried all the way to understand the error but failed to solve the issue.
Error shows as below. Anyone got same kind of issues or any solutions would be a great help.
If you are running bigip 11.5.3 on viprion, you may hit a bug that we get an engineering HF. The issue is fixed in 11.6.1
