Mohammad_Hossei's avatar
Mohammad_Hossei
Jun 13, 2018
switch -glob issue with URI tolower string
Hi Guys, I expect this irule to be working for me based on my URI but it is not working. it only supports lowercases and can't detect anything in Capital like Lion or TIGER. Please help if you have any idea.
when HTTP_REQUEST { switch -glob [string tolower [HTTP_uri]] { "/lion" { pool test1 member 1.1.1.1:8080 } "/tiger" { pool test1 member 1.1.1.2:8080 } "/mouse*" { pool test1 member 1.1.1.3:8080 } default { HTTP::redirect "/tiger" } } }
  • JG's avatar
    JG
    You had a typo; also I'd use [HTTP::path] instead.
        switch -glob [string tolower [HTTP::path]] {
            "/lion" {
                        pool test1 member 1.1.1.1 8080
            "/tiger" {
                         pool test1 member 1.1.1.2 8080
            "/mouse*" {
                          pool test1 member 1.1.1.3 8080
            default {
  • The problem when you anonymize the code is to check if the code you applied is correct!
    if you convert URI or PATH (as suggested Jie) to lowercase, the switch condition must be lowercase.
    for example :
            --> will match /lion /Lion /LION /LioN
            "/Tiger" { pool test1 member 1.1.1.2:8080 }
            --> will never match because you compare a lowercase string with a string with a uppercase character
            --> will match /mouse /Mouse / /MOUSE /mousekdjghflh /MOuse/images/front.png
