J__Pogeant_1557
May 26, 2014Sync problem with Sync-Failover ConfigSync
Hello,
I'm running two BigIp LTM (version 11.3 HF3) with Sync-Failover ConfigSync. I'm experiencing issues with the synchronisation on both devices.
All the configuration is well replicated excepts for the Virtual Server List in a particular Partition. On the other partition, the configuration is synchronised.
After digging on F5 support and devcentral, I've tried many workarounds :
- Reboot both nodes
- Create "dummy" elements to force the configuration to be considered as "new"
- http://support.f5.com/kb/en-us/solutions/public/13000/900/sol13946.html
- http://support.f5.com/kb/en-us/solutions/public/13000/800/sol13887.html
None of them worked, the devices always consider themselves as "In Sync", but they still keep a different configuration on their side even by forcing the
sync-leader
This only happens with the Virtual Server configuration on this particular partition.
The configuration is well synced on the other partitions....
If anyone could have a clue or a way to debug this problem that would greatly appreciated 🙂
Thanks in advance.
