Sort By
- Simon_BlakelyEmployee
You would generally install the certificate on the LTM virtual servers that load-balances traffic to your TFS servers, to offload TLS/SSL to the LTM. You may also install the certificate on to your TFS servers to maintain end-to-end TLS/SSL encryption.
do i need the cert to contain all the cnames into it as alaises?
If your certificate is not a wildcard for the domain, then you may need to include Subject Alternative Names
