- zamroni777Nacreous
if you use heavy irules, try to reduce the log action or convert them to local traffic policy.
avr analytics should be also disabled for live traffic.if youre backedn traffic is http/s, enable oneconnect in http profile to reduce number of tcp connections to backedn servers.
- Aswin_mkCumulonimbus
Usually any cpu hike to 100%, it will make traffic disruption and uneven load balancing in pool. In the attached link it's mentioned what is MHDAG, cause and resolution.
https://cdn.f5.com/product/bugtracker/ID700827.html
