Sadorect_151355's avatar
Sadorect_151355
Dec 14, 2015
Troubleshooting BIG-IP Power Failure
Hello,
I have the qkview from a device which experienced a power failure. The qkview is currently uploaded to ihealth. Please, which logs am I supposed to check to see the logged info regarding the power failure?
I searched for the keyword "power" in the logs and turned up one entry in the var/log/ltm log but couldn't locate anything descriptive about power failure. Please help, thanks very much.
  • Hi,
    To see the power supply status:
    tmsh show /sys hardware
    To see the logs about the power failure, it is indeed in /var/log/ltm -or any /var/log/ltm.* archive-, try searching for "power" and "Power", what log entry did you get?
