smiley_dba_1116's avatar
smiley_dba_1116
Feb 28, 2016
URI Tracker - Question - ERROR: undefined procedure: swith][swith -glob [string tolower [HTTP::uri]]
URI tracker code is driving me nutts. I dont know if my backets are screwed up or if my HTTP::uri is screwed. For awhile, I was getting a cross bracket error, but after using Notepad++, I THINK i got them all. Now Im getting the attached error now. has anyone else used the Link tracker and had issues with the code parsing?
set TABLE_LINK "LINK_TRACKING_[virtual name]";
set TABLE_FILTERS "LINK_TRACKING_FILTERS_[virtual name]";
swith -glob [string tolower [HTTP::uri]] {
"/linkadmin*" {
set count_filter "";
set data_filter "";
set msg [URI::decode [getfield [HTTP::uri] "/" 3]]
if { ($msg starts_with "f(") && ($msg ends_with ")") } {
set data_filter [string range $msg 2 end-1];
set msg "";
} elseif { ($msg starts_with "c(") && ($msg ends_with ")") } {
set count_filter [string range $msg end-1];
set data_filter "";
set msg "";
set count [table keys -subtable $TABLE_LINK -count]
set content {URI tracking
URI Tracking
append content "$TABLE_LINK"
append content "Link Count$count"
append content {Controls
append content "URI Filters"
foreach key [table keys -subtable $TABLE_FILTERS] {
append content "\[\] $key
append content "";
append content {Add Filter
if { "" !=$msg } {
append content "Message%msg";
append content "";
append content ""
append content "Link Metrics";
append content "URICount";
append content {Filter Results }
append content " []
append content " []
foreach key [lsort -dictionary [table keys -subtable $TABLE_LINK]] {
if { "" !=$data_filter } {
if { [string match $data_filter $key] } {
set v [table lookup -subtable $TABLE_LINK $key];
append content "\[\] $key$v";
}elseif { "" != $count_filter } {
if { $v >= $count_filter } {
append content "";
HTTP::respond 200 Content $content;
"/linkcleardata"{
table delete -subtable $TABLE_LINK -all;
HTTP::redirect "http://[HTTP::host]/linkadmin/link+Tracking+Cleared"
"/linkremovedata/*" {
set val [string range [HTTP::uri] [string length "linkremovedata/"] end]
if { "" != $val }{
table delete -subtable $TABLE_LINK $val;
HTTP::redirect "http://[HTTP::host]/linkadmin/Link+Deleted";
"/linkclearfilter" {
table delete -subtable $TABLE_FILTERS -all;
HTTP::redirect "http://[HTTP::host]/linkadmin/Link+Filters+Cleared"
"/linkaddfilter/*" {
set f [string range [HTTP::uri][string length "/linkaddfilter/"] end]
if { "" != $f}{
table add -subtable $TABLE_FILTERS $f 1 indefinite indefinite;
HTTP::redirect "http://[HTTP::host]/linkadmin/Filter+Added";
"/linkremovefilter/*" {
set val [string range [HTTP::uri][string length "linkremovefilter/"] end]
if { "" != $val }{
table delete -subtable $TABLE_FILTERS $val;
HTTP::redirect "http::/[HTTP::host]/linkadmin/Filter+Deleted";
default {
set match 1;
set c [table keys -subtable $TABLE_FILTERS -count]
if { $c != 0 } {
set match 0;
foreach key [lsort [table keys -subtable $TABLE_FILTERS]] {
set m [string match $key [HTTP::uri]];
if { 1 == $m } {
set match 1;
break;
  • First issue I found after walking away is that i mispelled switch with swich. still getting errors. 01070151:3: Rule [/Common/test] error: /Common/test:16: error: [wrong args][string range $msg end-1] /Common/test:84: error: [undefined procedure: /linkcleardata]["/linkcleardata"{ table delete -subtable $TABLE_LINK -all; HTTP::redirect "http://[HTTP::host]/linkadmin/link+Tracking+Cleared"
  • There's a } missing before the "/linkcleardata".
    I don't have an F5 on me at the moment, so i can't confirm if there are any other errors.
    HTH.
  • ok. I tried that, but still getting that clear data issue.
    Error /linkcleardata]["/linkcleardata" { table delete -subtable $TABLE_LINK -all;
    "/linkadmin*" {
    set data_filter "";
    set msg "";
    set count_filter [string range $msg 2 end-1];
    set data_filter "";
    set msg "";
    URI Tracking
    append content "";
    if { "" !=$msg } {
    append content "";
    append content ""
    append content "x]
    append content " []
    foreach key [table keys -subtable $TABLE_LINK] {
    if { "" != $data_filter } {
    } elseif { "" != $count_filter } {
    append content "";
    "/linkcleardata" {
    HTTP::redirect "http://[HTTP::host]/linkadmin/Link+Tracking+Cleared"
    if { "" != $val }{
    "/linkclearfilters" {
    if { "" != $f}{
    if { "" != $val }{
    default {
    set match 1;
    if { $c != 0 } {
    set match 0;
    if { 1 == $m } {
    set match 1;
    break;
  • Hi Smiley,
    reworked your code formatings and catched almost a dozend TCL/HTML glitches.
    I've changed a little bit your sytax to rely more on substitution instead of switching between "" and {} escaped $content. The new code will only leave HTML when you have to [if] or [foreach] dynamic HTML code.
        switch -glob [string tolower [HTTP::uri]] {
            "/linkadmin*" {
                set count_filter ""
                set data_filter ""
                if { ($msg starts_with "f(") && ($msg ends_with ")") } then {
                    set count_filter ""
                    set msg ""
                } elseif { ($msg starts_with "c(") && ($msg ends_with ")") } then {
                    set data_filter ""
                    set msg ""
                set content "
            URI tracking
                                    URI Tracking
                                    $TABLE_LINK
                                    Link Count
                                    $count
                                    Controls
                                    URI Filters
                append content "
                                    Add Filter
                if { "" !=$msg } then {
                    append content "
                                    Message
                                    $msg
                append content "
                                    Link Metrics
                                    URI
                                    $count
                                    Filter Results
                    if { "" != $data_filter } then {
                        if { [string match $data_filter $key] } then {
                            append content "
                                    \[\] $key
                                    $v
                    } elseif { "" != $count_filter } then {
                            append content "
                                    \[\] $key
                                    $v
                        append content "
                                    \[\] $key
                                    $v
                append content "
            "/linkcleardata" {
                if { "" != $val } then {
                set f [string range [HTTP::uri] [string length "/linkaddfilter/"] end]
                if { "" != $f} then {
                set val [string range [HTTP::uri] [string length "linkremovefilter/"] end]
            default {
                set match 1
                if { $c != 0 } then {
                    set match 0
                        if { 1 == $m } then {
                            set match 1
                            break
    Note: Just saved the iRule for debugging purposes. But didn't executed the iRule at all.
    Cheers, Kai
