See the links below as you need to capture the payload and then find the string and do maybe "if else" to send to different pools based on the payload.
https://support.f5.com/csp/article/K07535385
https://clouddocs.f5.com/api/irules/HTTP__payload.html
https://community.f5.com/t5/crowdsrc/simple-iruleslx-json-rewrite/ta-p/289095
- Andrew_Lagomarc
I've been given some clarification on what they are asking. They want me to inspect the JSON data set paramters and then if they match a certain set, then update them to a newer data set that includes slightly different parameters.
I am not quite putting all those articles together can you help me understand the shell of what I would be required to write for this?It sounds like the first reply you got from Nikoolayy1 is closest to the solution you are looking for. And this post: https://community.f5.com/t5/crowdsrc/simple-iruleslx-json-rewrite/ta-p/289095 seems the best starting point, since you'll need to modify the JSON payload.
This solution makes use of iRulesLX. These videos are a good starting point to learn more about iRules and how to use them on your BIG-IP: https://www.youtube.com/watch?v=Gh3hfFHoj1w
