Gilberto
Jun 17, 2019Solved
Using monitors in iRules
Hi:
I have the next question, Is possible use the state that mark one monitor in an iRule?, That is because I have three monitors configurated in one node (2 ICMP monitors and one inbound monitor) and I need that the node is mark down when inbound node is down even if the rest of the monitors are up.
Yes, it's possible.
You can configure 3 pools (one with each monitor pointing the same node).
After that, you can use "active_members" command to check the state of those pools.
https://clouddocs.f5.com/api/irules/active_members.html
KR,
Dario.
