Hi there. Sorry for the delay. Since you are using the /Common/f5-aws-dns resolver, did you modify it to include the zone for which your fqdn resides? For example, if I'm going to look up espn.com on my local test box, my aws resolver would need to look like this:
net dns-resolver f5-aws-dns {
forward-zones {
amazonaws.com {
nameservers {
8.8.8.8:domain { }
espn.com {
nameservers {
8.8.8.8:domain { }
idservice.net {
nameservers {
8.8.8.8:domain { }
shpapi.com {
nameservers {
8.8.8.8:domain { }
route-domain 0
And if I change my iRule to do more logging like this:
when CLIENT_ACCEPTED {
set fqdn espn.com
set lookup_result [RESOLVER::name_lookup "/Common/f5-aws-dns" $fqdn a]
log local0.debug "Lookup: $lookup_result"
set lookup_summary [RESOLVER::summarize $lookup_result]
log local0.debug "Summary: $lookup_summary"
foreach rr $lookup_summary {
log local0.debug $rr
log local0.debug [lindex $rr 4]
Then my results are:
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: Lookup: 000081800001000400000000046573706E03636F6D0000010001C00C000100010000003B00046354A008C00C000100010000003B00046354A00AC00C000100010000003B00046354A037C00C000100010000003B00046354A044
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: Summary: {espn.com. 59 IN A 99.84.160.8} {espn.com. 59 IN A 99.84.160.10} {espn.com. 59 IN A 99.84.160.55} {espn.com. 59 IN A 99.84.160.68}
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.8V
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.8
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.10
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.10
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.55
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.55
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.68
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.68
I added espn.com to the aws resolver since you're using it, but in a real scenario, I'd create a standalone resolver specifically for the iRule instead of modifying the aws one.
