Christian_Laute
May 02, 2017Nimbostratus
Using variables in external Perl monitor
Gents, I currently use a external monitor to check the JSON output of some webservices. Now I try to make it a little bit more flexible.
For example I want to try to replace the string "UP" at if($status eq "UP") to if($status eq $statusmsg) but not sure how to do this.
Current script:
!/usr/bin/env perl
use LWP::Simple;
use JSON;
$URI = $ARGV[2];
$HOSTNAME = $ARGV[0];
$HOSTNAME =~ s/::ffff://;
$PORT=$ARGV[1];
$contents = get("http://$HOSTNAME:$PORT$URI");
$json = decode_json($contents);
$status = $json->{'status'};
if($status eq "UP") {
print $status;
Typing in the variable like below did not help. Also hard to find any documentations about it....
Maybe anyone of you can help me out? Many thanks
