Edouard
Jul 17, 2019Cirrus
Solved
vcmp system factory default
Hi Gents,
I need to factory reset a host that has 3 guests in the host. Can you advise how I can reset all to factory default deleting those guests as well.
Thank-you.
Have a look at the following article:
https://support.f5.com/csp/article/K13127
The one thing you will likely need to do is delete the guests first as the files for them will reside in the /shared partition.
Depending on the reason for wanting to wipe it (selling off etc) then clean install and wiping the disks are the best option.
Here's the article for clean installing.
https://support.f5.com/csp/article/K13117
Cheers,
