Sort By
- youssef1
Cumulonimbus
Hello,
it's easy to do it, you can follow this procedure:
https://devcentral.f5.com/articles/creating-a-ssl-vpn-using-f5-full-webtop-30146
So just keep in mind that you need 3 important things: - Webtop - network access (you will network behaviour: split or full VPN) - connectivity profile
as soon as you set this 3 things you can use an edge client (mobile or laptop).
How I can help you? you already try to deploy a VPN? on nothing for the moment...
Regards,
