Create an internal HTTP Load-Balancer on Volterra with Terraform
Problem this snippet solves:
How to create an internal HTTP Load-Balancer with VoltMesh where the Origin is reachable through a Volterra node.
Two steps are needed:
- Creation of the Origin (1-origin.tf file)
- Creation of the Load-Balancer (2-http-lb.tf file)
How to use this snippet:
Pre-Requirements:
- Have a Volterra API Certificate. Please see this page for the API Certificate generation: https://volterra.io/docs/how-to/user-mgmt/credentials
- Extract the certificate and the key from the .p12:
openssl pkcs12 -info -in certificate.p12 -out private_key.key -nodes -nocerts openssl pkcs12 -info -in certificate.p12 -out certificate.cert -nokeys
- Create a variables.tf Terraform variables file:
variable "api_cert" { type = string default = "/<full path to>/certificate.cert" } variable "api_key" { type = string default = "/<full path to>/private_key.key" } variable "api_url" { type = string default = "https://<tenant_name>.console.ves.volterra.io/api" }
- Create a main.tf Terraform file:
terraform { required_version = ">= 0.12.9, != 0.13.0" required_providers { volterra = { source = "volterraedge/volterra" version = ">=0.0.6" } } } provider "volterra" { api_cert = var.api_cert api_key = var.api_key url = var.api_url }
In the directory where your terraform files are, run:
terraform init
Then:
terraform apply
Code :
//========================================================================== //Definition of the Origin, 1-origin.tf //Start of the TF file resource "volterra_origin_pool" "sample-http-origin-pool" { name = "sample-http-origin-pool" //Name of the namespace where the origin pool must be deployed namespace = "mynamespace" origin_servers { private_ip { ip = "10.17.20.13" //From which interface of the node onsite the IP of the service is reachable. Value are inside_network / outside_network or both. outside_network = true //Site definition site_locator { site { name = "name-of-the-site" namespace = "system" tenant = "name-of-the-tenant" } } } labels = { } } no_tls = true port = "80" endpoint_selection = "LOCALPREFERED" loadbalancer_algorithm = "LB_OVERRIDE" } //End of the file //========================================================================== //========================================================================== //Definition of the Load-Balancer, 2-http-lb.tf //Start of the TF file resource "volterra_http_loadbalancer" "sample-http-lb" { depends_on = [volterra_origin_pool.sample-http-origin-pool] //Mandatory "Metadata" name = "sample-http-lb" //Name of the namespace where the origin pool must be deployed namespace = "mynamespace" //End of mandatory "Metadata" //Mandatory "Basic configuration" domains = ["mydomain.internal"] http { dns_volterra_managed = false } //End of mandatory "Basic configuration" //Optional "Default Origin server" default_route_pools { pool { name = "sample-http-origin-pool" namespace = "mynamespace" } weight = 1 } //End of optional "Default Origin server" //Mandatory "VIP configuration" advertise_on_public_default_vip = true //End of mandatory "VIP configuration" //Mandatory "Security configuration" no_service_policies = true no_challenge = true disable_rate_limit = true disable_waf = true //End of mandatory "Security configuration" //Mandatory "Load Balancing Control" source_ip_stickiness = true //End of mandatory "Load Balancing Control" } //End of the file //==========================================================================
Tested this on version:
No Version FoundPublished Oct 13, 2021
