Java System Info
Problem this snippet solves:
This Java application illustrates how to query system information from a BIG-IP with Java.
This sample is the companion code for the "Getting Started With iControl And Java - Setting Up Eclipse" Tech Tip on DevCentral. It illustrates how to setup the iControl interfaces object and query system information from the BIG-IP with Java and iControl.
Code :
public class SystemInfo { public iControl.Interfaces m_interfaces = new iControl.Interfaces(); public void usage() { System.out.println("Usage: SystemInfo hostname username password"); } public void Run(String [] args) throws Exception { if ( args.length < 3 ) { usage(); } else { String host = args[0]; String user = args[1]; String pass = args[2]; boolean bInit = m_interfaces.initialize(host, user, pass); if ( bInit ) { getSystemInformation(); } } } public void getSystemInformation() throws Exception { iControl.SystemSystemInformation sysInfo = m_interfaces.getSystemSystemInfo().get_system_information(); System.out.println("======================================================"); System.out.println(" System Information"); System.out.println("------------------------------------------------------"); System.out.println("System Name : " + sysInfo.getSystem_name()); System.out.println("Host name : " + sysInfo.getHost_name()); System.out.println("OS Release : " + sysInfo.getOs_release()); System.out.println("OS Machine : " + sysInfo.getOs_machine()); System.out.println("OS Version : " + sysInfo.getOs_version()); System.out.println("Platform : " + sysInfo.getPlatform()); System.out.println("Product Category : " + sysInfo.getProduct_category()); System.out.println("Chassis Serial : " + sysInfo.getChassis_serial()); System.out.println("Switch Board Serial : " + sysInfo.getSwitch_board_serial()); System.out.println("Switch Board Part Revision : " + sysInfo.getSwitch_board_part_revision()); System.out.println("Host Board Serial : " + sysInfo.getHost_board_serial()); System.out.println("host Board Part Revision : " + sysInfo.getHost_board_part_revision()); System.out.println("Annunciator Board Serial : " + sysInfo.getAnnunciator_board_serial()); System.out.println("Annunciator Board Part Revision : " + sysInfo.getAnnunciator_board_part_revision()); } /** * @param args */ public static void main(String[] args) { try { SystemInfo sysInfo = new SystemInfo(); sysInfo.Run(args); } catch(Exception ex) { ex.printStackTrace(System.out); } } }
Published Mar 08, 2015
