Periodic iCall script to auto-generate NodeIP-to-NodeName datagroup
Problem this snippet solves:
Hi Folks,
the iCall script and handler below can be used to auto-generate a NodeIP-to-NodeName datagroup on scheduled intervals. The auto-generate datagroup can then be used to resolve the
[LB::server addr]
output to the coresponsing node name label using the [class match -value]
syntax.
Cheers, Kai
How to use this snippet:
- Tweak the periodic intervals (in seconds) of the iCall handler as needed.
- Import the provided iCall script and handler using the tmsh load config merge from-terminal syntax
- Take a look to the configured data-groups and LTM logfiles to verify the results.
- Use
within an iRule to resolve the name of a selected pool member.[class match -value [LB::server addr] DG_IP_2_NODENAME]
Code :
sys icall script DataGroup_NodeIP_to_NodeName { app-service none definition { set nodelist "" set nodecounter 0 # tmsh::log "iCall: Starting to enumerate existing node objects..." foreach partition [tmsh::get_config auth partition] { set partition "/[tmsh::get_name $partition]" # tmsh::log "iCall: Processing Partition: $partition" tmsh::cd $partition set nodes [tmsh::get_config /ltm node] foreach node $nodes { # tmsh::log "Processing Node : $partition/[tmsh::get_name $node]" append nodelist "\"[tmsh::get_field_value $node "address"]\" \{ data \"[tmsh::get_name $node]\" \}\n" incr nodecounter } # tmsh::log "Finished Partition: $partition" } tmsh::cd "/Common" if { not ([tmsh::list /ltm data-group] contains "ltm data-group internal DG_IP_2_NODENAME") } then { tmsh::log "iCall: Created the data-group \"DG_IP_2_NODENAME\"." tmsh::create /ltm data-group internal "DG_IP_2_NODENAME" type "string" } else { # tmsh::log "iCall: The DataGroup does exist." } eval "tmsh::modify /ltm data-group internal DG_IP_2_NODENAME \{ records replace-all-with \{ $nodelist \} \}" tmsh::log "iCall: Updated the data-group DG_IP_2_NODENAME with \"$nodecounter\" entries." } description none events none } sys icall handler periodic DataGroup_NodeIP_to_NodeName { first-occurrence 2016-09-12:00:00:00 interval 60 script DataGroup_NodeIP_to_NodeName }
Tested this on version:
12.0Updated Jun 06, 2023
Version 2.0
