SOCKSv4 protocol parsing and IP/Port/Hostname rewrites
Problem this snippet solves:
Hi Folks,
the provided iRule can be used to parse SOCKSv4 connection request and to rewrite the connection attemps to a given IP/Port/Hostname to a different IP/Port/Hostname.
Cheers, Kai
How to use this snippet:
  1. Tweak the RULE_INIT settings as required
  2. Attach the iRule to your Virtual Server which is serving your SOCKSv4 Proxy.
  3. Connect to the IP/Port/Hostname via SOCKSv4 as usual.
  4. Check if the connection was forwarded to the new host.
Code :
when RULE_INIT {
    set static::socks_debug 1
    # Set the original and new destination HOST
    set static::orig_host "1.1.1.1:22"
    set static::new_host "2.2.2.2:22"
    set static::orig_hostname "dummy1.domain.de"
    set static::new_hostname "dummy2.domain.de"
    # Formating static::orig_host value to socks compliant host string
    scan $static::orig_host %d.%d.%d.%d:%d ip1 ip2 ip3 ip4 port
    set static::orig_host_hex [format %4.4x $port]
    foreach octed "$ip1 $ip2 $ip3 $ip4" {
        append static::orig_host_hex [format %2.2x $octed]
    # Formating static::new_host value to socks compliant host string
    scan $static::new_host %d.%d.%d.%d:%d ip1 ip2 ip3 ip4 port
    set static::new_host_hex [format %4.4x $port]
        append static::new_host_hex [format %2.2x $octed]
    binary scan $static::orig_hostname H* static::orig_hostname_hex
    binary scan $static::new_hostname H* static::new_hostname_hex
when CLIENT_ACCEPTED {
    TCP::collect
when CLIENT_DATA {
    catch {
        if { $static::socks_debug } then {
            binary scan [TCP::payload] H2H1H4H2H2H2H2H* socks_version socks_command socks_port socks_ip1 socks_ip2 socks_ip3 socks_ip4 socks_username
            log local0.debug "Socks Request received: Version=[expr { "0x$socks_version" }], Command=[expr { "0x$socks_command" }] , DST_Port=[expr { "0x$socks_port" }] , DST_IP=[expr { "0x$socks_ip1" }].[expr { "0x$socks_ip2" }].[expr { "0x$socks_ip3" }].[expr { "0x$socks_ip4" }] , Username = [binary format H* $socks_username]"
        binary scan [TCP::payload] H* orig_socks_payload
        if { $orig_socks_payload contains $static::orig_hostname_hex } then {
                log local0.debug "Socks Request requires HOSTNAME rewrite..."
            set new_socks_payload [string map "$static::orig_hostname_hex $static::new_hostname_hex" $orig_socks_payload]
            TCP::payload replace 0 [TCP::payload length] [binary format H* $new_socks_payload]
        } elseif { $orig_socks_payload contains $static::orig_host_hex } then {
                log local0.debug "Socks Request requires IP rewrite..."
            set new_socks_payload [string map "$static::orig_host_hex $static::new_host_hex" $orig_socks_payload]
    TCP::release
Tested this on version:
12.0
Published Sep 08, 2016
Was this article helpful?
