Michel_van_der_
Jul 05, 2006Nimbostratus
Default node monitor?
On a load balancer, when I go to:
Local Traffic -> Nodes -> Default Monitor
I can set up a default monitor for my nodes.
How do I do the same in iControl?
Thanks, Michel
Thanks, Michel
I am trying to produce code and good quality examples for set_monitor_association and get_monitor_association HERE for NodeAddress:
Although the set does not throw an exception, it DOES NOT change the monitor association for a node. The get_monitor_association works and might server as an example.
Are we stating that NodeAddress:set_monitor_association is broken in 9.4?
Thanks much.
