Mubasher_Sultan
Sep 09, 2013Nimbostratus
Device OFFLINE ?
Dear folks,
What is the mean of OFFLINE in Device Management >> Device Tab
I will be having the access from management port?
IS this correct?
Regards, Mubasher
Dear folks,
IS this correct?
Regards, Mubasher
i understand you are still able to connect to non-floating selfip.
About device status
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-redundant-systems-config-11-1-0/2.html
Offline means it will not become active for any of the traffic groups.
The setting is helpful if you plan to break your device group i.e. by setting a new device name, changing the device cert or resetting the device trust.
If your device group runs unintended active/active it might be helpful to get a stable situtation by forcing one unit into offline mode:
tmsh run sys failover offline
Release after recovery by:
tmsh run sys failover online
The unit will still have self IPs up i.e. to monitor nodes / pool members or to be reachable for inband management. Out of band (mgmt port) is available as well.
