Dazzla_20011
Apr 12, 2011Difference between tcp and tcp half open monitor
What's the difference between the a tcp and tcp half open montor?
I thought the Tcp monitor just checked the tcp three way hadshake and tcp half open just checked SYN-ACk is received?
We have an application which falls over when I apply the default tcp monitor. How can check if the LTM is closing the tcp connection for the monitor and also would the tcp half open be a better option just for checking the status of a tcp port?
Darren
