Kevin_Davies_40
Jun 11, 2014Nacreous
Do the following command from your F5. This assumes the pool member is on port 443. If not then add :port to then end of pool_member_ip with the port of the pool member you are testing.
curl -k https://pool_member_ip/monitor/status_check
Do you get something back?
- Ellison_Zhang_2May 11, 2016NimbostratusI got expected string "OK" when I use curl -k. but HTTPS monitor still failed.
