DannyG_34437
Mar 12, 2014Cirrus
Is edge client required to check for cert on IOS mobile device?
Hi, I have an LTM/APM environment. I am currently trying to setup authentication certificate checks to mobile IOS devices. If I use the edge client and vpn tunnels, all works just fine (cert checking and access). I am running the IBM content navigator app on the device and would like to connect direct using straight SSL without using the edge client. Is it possible to check the certificate on the IOS device without using the edge client?
Thanks, dg
