Ichnafi's avatar
Ichnafi
Feb 08, 2023
Modify vCMP-Guest with ansible not possible?
Hello fellow F5ers,
I try to build an ansible playbook that performs the following:
  1. Get Names of trunk from vCMP-Host ->  got it by using module bigip_device_info
  2. Create a new VLAN and add it to the trunk from 1. -> got it by using moule bigip_vlan
  3. Add the newly created VLAN to a vCMP-Guest -> nope...
    1. use module  bigip_vcmp_guest? Nope, only for creating new guests
    2. create vlan also on the guest using anisble? Nope, will not make VLAN usable in guest
So, is there no other way of modifying the available VLANs fpr a vCMP-Guest, than using the TMSH command to modify the guest and run it with ansible's bigip_command module? What about idempotency?
modify vcmp guest <guest-name> vlans add { <vlan-name> }
  • Ichnafi's avatar
    Ichnafi
    Feb 17, 2023
    Hello Matt_Mabis ,
    thank you for your answer.
    I can confirm, that one can add VLANs to a vcmp-guest like this, but:
    You have to list all the existing vlans next to the new one as well. You can't just add a new one. The module replaces all VLANs of the guest with the ones listed in the "vlans" section of the module.
    I find this rather awkward. To add a VLAN to a guest, without knowing or careing what VLANs were configured previosly you had to:
    1. Use module bigip_device_info to query information about all vCMP-guest on a vCMP-Host
    2. Filter the output by the name of the vCMP-Guest you like to update and get the list of currently configured vlans
    3. append the new vlan to the list
    4. apply the extended list to the guest
    vars:
      guest_to_modify: "Guest1"
      vlan_tobe_added: "/Common/fancy-new-vlan"
    tasks:
      - name: Get vCMP-Guest Info
        bigip_device_info:
          gather_subset:
            - vcmp-guests
          provider: "{{ bigip_provider }}"
        register: device_info
        delegate_to: localhost
      - name: Filter for specific guest and build a list with new vlan
        set_fact:
          list_current_vlans: "{{ device_info.vcmp_guests|selectattr('full_path', 'match', guest_to_modify) | map(attribute='vlans') }}"
          list_with_added_vlan: "{{ list_current_vlans[0] + [vlan_tobe_added] }}"
      - name: Add VLAN to vCMP-Guest
        bigip_vcmp_guest:
          name: "{{ guest }}"
          vlans: "{{ list_with_added_vlan }}"
     Anyway. I tested it and it worked for me. the abillity to just add a new vlan would be better i guess, but I'll take it.
    Thank you very much!
  • Hey there Ichnafi!
    I Tested code out for myself and got it working with bigip_vcmp_guest, here is the code i used you can see the first and second tasks creates 2 VCMP Guest Instances and the 3rd task of code modifies the existing created VCMP Guest, no ping loss no packet drops from my testing.
    - hosts: localhost
      connection: local
      gather_facts: false
      vars_files:
        - /git/vars/lab/vault.yml
      tasks:
      - name: Create a vCMP guest with specific VLANs
        bigip_vcmp_guest:
          mgmt_network: bridged
          mgmt_address: 192.168.1.60/24
          mgmt_route: 192.168.1.1
          vlans:
            - VLAN5
          initial_image: "BIGIP-15.1.0.4-0.0.6.iso"
          provider:
            password: "{{ f5_password }}"
            server: 192.168.1.50
            user: "{{ f5_username }}"
            validate_certs: false
        bigip_vcmp_guest:
          mgmt_address: 192.168.1.61/24
          vlans:
            - VLAN2101
          state: configured
          provider:
      - name: Modify a vCMP guest with specific VLANs
        bigip_vcmp_guest:
          vlans:
            - VLAN5
            - VLAN2101
          provider:
    Output from Code Run
    Ansible Playbook Version - 2.14.1
    Ansible Galaxy Collection - 1.21.0
    • Ichnafi's avatar
      Ichnafi
      Hello Matt_Mabis ,
      vars:
      tasks:
          bigip_device_info:
            gather_subset:
              - vcmp-guests
          set_fact:
          bigip_vcmp_guest:
            name: "{{ guest }}"
      • Matt_Mabis's avatar
        Matt_Mabis
        Totally understand where you are coming from, I think they would have had to create a different module for that scenario.   The removal of a vlan would have created complications against bigip_vcmp_guests module as a "absent" status trying to remove a vlan would probably tell the system to remove the entire guest not just a vlan..
        Glad you were able to figure out a solution.
  • Hi Ichnafi  - I see that nobody has answered your question yet, so I'm featuring it in today's Community Highlights article as an unanswered question, and sharing this with a colleague for some help.
