Fallout1984's avatar
Fallout1984
Aug 31, 2021
"re-starting big3d" over and over...
I have a lab virtual F5 running v14.1.4 and noticed a "re-starting big3d" message over and over when logged in via SSH.
Broadcast message from systemd-journald@F5Lab01.mystuff.net (Tue 2021-08-31 13:52                             :30 CDT):
logger[28346]: Re-starting big3d
2021 Aug 31 13:52:30 F5Lab01.mystuff.net logger[28346]: Re-starting big3d
So far I've tried manually restarting big3d and httpd, then stopping/starting big3d and httpd, even rebooting the F5 and big3d is still re-starting. I also ran a load sys config verify in case anything odd appeared there, but it looked fine.
Has anyone seen this before? If so, how did you resolve it?
Thanks!
  • Hello Fallout.
    It's difficult to diagnose this behavior without context, but big3d is related with DNS and iQuery communication.
    REF - https://support.f5.com/csp/article/K13703
    First, check if you have the DNS module enabled and if there is an iQuery tunnel established with another peer that could be failing (maybe certs or something else).
    If the issue persists, you could try to reinstall the big3d daemon from another device.
    big3d_install -use_ssh <target IP>
    REF - https://support.f5.com/csp/article/K13312
    Regards,
    Dario.
  • Hello Fallout.
    Regards,
    Dario.
  • Dario,
    Thanks for the info! I was able to resolve it using the info from https://support.f5.com/csp/article/K13703
    that you provided.
    When I initially displayed big3d, this is what I saw...
    [root@F5Lab01:Active:Standalone] config # ls -al /shared/bin/big3d /usr/sbin/big3d
    -rwxr-xr-x. 1 root root 5177018 Sep 17 2018 /shared/bin/big3d
    -rwxr-xr-x. 1 root root 5868113 Feb 11 2021 /usr/sbin/big3d
    So I used this procedure from the article to delete it...
    Log in to the BIG-IP command line.
    Note: In this example, on the software slot running 11.5.3.
    Stop the big3d daemon by typing the following command:
    tmsh stop /sys service big3d
    Remove the copy of big3d in /shared/bin directory by typing the following command:
    rm /shared/bin/big3d
    Note: The BIG-IP system will automatically copy the 11.5.3 version of big3d from /usr/sbin/big3d to /shared/bin directory.
    Start the big3d daemon, type the following command:
    tmsh start /sys service big3d
    ...and after that it showed this:
    -rwxr-xr-x. 1 root root 5868113 Feb 11 2021 /shared/bin/big3d
    The big3d restart messages have not returned.
    Thanks for your help!
    Alan
