Ryan_80361
Yes. Both the MSSQL and MySQL monitors have fields where you can put an alias address (the address of the SQL server you want to check) and depending on whether the check is successful or not your pool member(s) will be marked UP/DOWN.
patonbike
Aug 10, 2018Cirrus
Thank you - I see those fields, but I don't have the ability to modify the field at least not from the monitor page. It just says :
All Addresses
- All Ports
