Mariusz_B
Nov 12, 2014Nimbostratus
Solved
Unusual health monitor.
Hello,
Is it possible to monitor a node which is not part of a pool, and mark the pool down when the monitor fails? I've managed to create health monitor with custom POST query which works fine, but the requirement is to NOT send any production traffic to the destination node. It's for monitoring purpose only.
Anyone come across a similar scenario?
Regards Mariusz
Hi, yes it's possible.
You can create custom monitor, in sections
define ip address of the node you need and inAlias Address
custom port. Set monitor to the pool, setAlias Service Port
to All. In case if this monitor fails pool will be mark down.Availability Requirement
