Upload small files (certs/keys/etc) to BIG-IP via iControl REST (base64 encoded using cli script)
Problem this snippet solves:
I had a need to upload SSL certificates and keys to the BIG-IP in a simple manner that was fast. I did so by creating a cli script that would accept a filename, base64 encoded file and the file type (ascii/binary), then would write out the file to disk.
How to use this snippet:
curl -sk -u username:password -X POST -H 'Content-Type: application/json' https://PRIMARY_F5/mgmt/tm/cli/script -d '{"command":"run","utilCmdArgs":"file_creation [filename] [filetype] [file_base64encoded"}'
Code :
create cli script fileupload { proc script::init {} { } proc script::run {} { package require base64 set filename [lindex $tmsh::argv 1] set filetype [lindex $tmsh::argv 2] set contents [lindex $tmsh::argv 3] if { [file exists $filename] == 0} { if { $filetype == "binary"} { set result [::base64::decode $contents] set finalfile [open $filename "w"] fconfigure $finalfile -encoding binary puts -nonewline $finalfile [::base64::decode $contents] close $finalfile return 0 } if { $filetype == "ascii"} { set result [::base64::decode $contents] set finalfile [open $filename "w"] fconfigure $finalfile puts -nonewline $finalfile [::base64::decode $contents] close $finalfile return 0 } } if { [file exists $filename] == 1} { puts "File already exists" error "File already exists" return 1 } } proc script::help {} { } proc script::tabc {} { } total-signing-status not-all-signed }
Tested this on version:
12.1Published Aug 13, 2019
