Building an OpenSSL Certificate Authority - Configuring CRL and OCSP
Updated Jun 06, 2023
Version 2.0Was this article helpful?
When you create the OCSP key & certificate, your sample code uses the openssl_server.cnf (which you don't introduce until the next article) but when you sign the certificate you use the openssl_intermediate.cnf.
Does it matter if you switch between the two? Is there that much difference between the two config files?
