How I did it - "Visualizing Data with F5 TS and Splunk"
Updated Dec 13, 2022
Version 2.0Was this article helpful?
Hello @abyanfaishal
I believe the command to fix as noted in the article you mentioned - https://my.f5.com/manage/s/article/K05413010 (see command below) will address the issue. Unfortunately, I don't know of a way to avoid the allowing loopback address.
Command - tmsh modify sys db tmm.tcl.rule.node.allow_loopback_addresses value true
tmsh save sys config
Thanks,
Greg
