Troubleshooting TLS Problems With ssldump
Published Oct 14, 2010
Version 1.0Was this article helpful?
Hi Ajit,
If you look closer the S>C is part of a different TCP connection (3), whereas initial C>S is 7. Maybe some asymmetric routing, missing SNAT?
Might be worth enabling ssl debugging and checking the logs: modify /sys db log.ssl.level value Debug
Cheers, Mariusz
