Using F5 BIG-IP Controller Operator for OpenShift
Today A&O PM and PD team announced the availability of Certified F5 BIG-IP Controller Operator (using Helm Charts) on OpenShift 4.x platforms. In this document we discuss about Install, Configure and Deploy CIS using RedHat Certified F5 BIG-IP Controller Operator on OpenShift 4.x Platforms.
Introduction
What is an Operator? - A method of packaging, deploying and managing a Kubernetes application. A Kubernetes application is an application that is both deployed on Kubernetes and managed using the Kubernetes APIs and kubectl/oc tooling. You can think of Operators as the runtime that manages this type of application on Kubernetes.
Conceptually, an Operator takes human operational knowledge and encodes it into software that is more easily packaged and shared with consumers.
F5 BIG-IP Controller Operator is a Service Operator which installs F5 BIG-IP Controller (Container Ingress Services) on OpenShift platforms 4.x.
Prerequisites
OpenShift 4.x
BIG-IP (F5 CIS supported versions)
In this document we will use Code Ready Containers to install, Configure and deploy CIS using F5 BIG-IP Controller Operator. CRC 1.7.0 installs OCP 4.3.1 on you laptop. Get your suitable image from CRC Repo and follow the instructions to install CRC and bringup your single node OCP 4.3.1 cluster.
Install, Configure and Deploy CIS using Operator
Accessing OCP 4.3.1 web console
From CLI, login as admin using CRC given credentials.
$ eval $(crc oc-env) $ oc login -u kubeadmin -p db9Dr-J2csc-8oP78-9sbmf https://api.crc.testing:6443
Here, the username is 'kubeadmin'. and password is 'db9Dr-J2csc-8oP78-9sbmf' to login OCP web console.
Installing Operator
From the left Menu bar, access Operator Hub and search for "f5" to see the Certified F5 BIG-IP controller Operator in the listing as below.
Click on Install to install this Operator.
Installing Operator is a guided process. The below screen shows different options to subscribe for this Operator. Select the highlighted options. Click subscribe.
Approval Strategy:
Manual: Requires administrator approval to install new updates.
Automatic: When a new release is available, updated automatic. (default)
When Operator is Subscribed, Operator is installed based on approval strategy. An Installed Operator screen is as below.
Configuring and Deploying F5 BIG-IP Controller Instance
Click on "F5 BIG-IP Controller" or "F5BigIPCtlr" under Provided APIs column to create an Instance of F5 BIG-IP Controller. Creating a F5BigIpCtlr instance screen is as shown below.
The Screen provides an editor to configure CIS/F5 BIG-IP Controller with required deployment options.
A sample Controller deployment configuration is as shown below
apiVersion: cis.f5.com/v1 kind: F5BigIpCtlr metadata: name: f5-server namespace: openshift-operators spec: args: manage_routes: true agent: as3 log_level: DEBUG route_vserver_addr: 172.16.1.4 bigip_partition: ocp openshift_sdn_name: /Common/openshift_vxlan bigip_url: 172.16.2.23 log_as3_response: true insecure: true pool-member-type: cluster bigip_login_secret: f5-bigip-ctlr-login image: pullPolicy: Always repo: k8s-bigip-ctlr user: f5networks namespace: kube-system rbac: create: true resources: {} serviceAccount: create: true version: latest
Create BIG-IP controller login secret and update the same in above configuration.
Update the YAML and click on Create. Based on Namespace and configuration options, CIS is installed.
When Operator deploys the controller, we can see the updated YAML of the CustomResource Instance. An example below.
Name: f5-server Namespace: openshift-operators Labels: <none> Annotations: <none> API Version: cis.f5.com/v1 Kind: F5BigIpCtlr Metadata: Creation Timestamp: 2020-02-08T00:31:21Z Finalizers: uninstall-helm-release Generation: 1 Resource Version: 245330 Self Link: /apis/cis.f5.com/v1/namespaces/openshift-operators/f5bigipctlrs/f5-server UID: 546d3890-4a0a-11ea-a1cf-0ef0e3c74fbe spec: args: agent: as3 bigip_partition: ocp bigip_url: 172.16.2.23 insecure: true log_as3_response: true log_level: DEBUG manage_routes: true openshift_sdn_name: /Common/openshift_vxlan pool_member_type: cluster route_vserver_addr: 172.16.1.4 bigip_login_secret: f5-bigip-ctlr-login Image: PullPolicy: Always Repo: k8s-bigip-ctlr Tag: latest User: f5networks Namespace: kube-system Rbac: Create: true Resources: Service Account: Create: true Name: <nil> Status: Conditions: Last Transition Time: 2020-02-08T00:31:21Z Status: True Type: Initialized Last Transition Time: 2020-02-08T00:31:23Z Message: F5 BIG-IP controller: f5-server General Controller Documentation: - Kubernetes: http://clouddocs.f5.com/containers/latest/kubernetes/index.html - OpenShift: http://clouddocs.f5.com/containers/latest/openshift/index.html Using Ingress? There's a helm chart for that: - https://github.com/F5Networks/charts/tree/master/src/stable/f5-bigip-ingress Using Routes in OpenShift? No helm chart yet, but we do have great documentation: - http://clouddocs.f5.com/containers/latest/openshift/kctlr-openshift-routes.html Reason: InstallSuccessful Status: True Type: Deployed Deployed Release: Manifest: . . . . . . . . . .
We can verify from CLI or GUI.
$ oc get pods -n kube-system NAME READY STATUS RESTARTS AGE f5-server-f5-bigip-ctlr-7c77d6846f-z7bhp 1/1 Running 0 112s
Congratulations! Your F5 BIG-IP Controller is deployed using F5 BIG-IP Controller Operator.
Additional Resources
Operator Code: https://github.com/F5Networks/k8s-bigip-ctlr/tree/master/operator
Operator Image: https://access.redhat.com/containers/#/registry.connect.redhat.com/f5networks/k8s-bigip-ctlr-operator
Known Issues
When Custom Resource Instance is created, instance listing doesn’t show Status [1] in the GUI.
[1] https://github.com/operator-framework/operator-sdk/issues/2491
